Proper LED current
Discussion in 'General Electronics Chat' started by Simon Larsen, Apr 28, 2015.
  1. Simon Larsen
    Feb 22, 2015
    31
    I have bought some led's with the following specs:
    Color: Red
    - Wave length: 620~625nm
    - Direct voltage: 1.9~2.1V
    - Counter current: < / = 10uA
    - Brightness: 800~1000MCD
    - Lighting angle: 30 degree
    without really thinking much about it I used them in a project where I had 5V and a 22o ohm resistor for each. So that would give I = 3/220=13mA pr. led. All was fine...
    ...then I started a new project and randomly used a 470 ohm resister - and brightness was actually fine! so my question is: how can I know which current-value is appropriate for a led?
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,694
    1,297
    The relationship between current in and light out is not linear. Also, the relationship between light out and perceived brightness is not linear. Combine these, and just looking at an LED is not a good indicator of what is going on inside it. Start with the datasheet and it's nominal or test current value. This is the manufacturer's opinion of the LED's sweet spot. From there, you can increase the current up to the max value if you need more brightness, or decrease it if you want less brightness or lower power operation. Vision is the most subjective of our five senses, so whatever looks best is the best answer as long as it is within the datasheet limits.
    ak
  3. dl324
    Mar 30, 2015
    3,377
    651
    Anything less than manufacturer maximum average power dissipation is appropriate. LEDs are typically spec'ed at 10-20mA (Vf, brightness, color, etc). The datasheet will also give a maximum forward current; this and maximum average PD are what you need to observe.
  4. #12
    Nov 30, 2010
    16,689
    7,329
    I keep telling people that you don't have to run your LEDs at the labeled maximum current. That's the MAXIMUM on the label. Whatever looks good to you is sufficient.
    Metalmann likes this.
  5. mcgyvr
    Oct 15, 2009
    4,791
    976
    Absolutely +1 for "indicator" LEDs..
    For "high current" LEDs used for "usable" light.. I drive it like I stole it :D
    (but I also heatsink it properly)
    Metalmann and #12 like this.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    I second all of the above. As long as you aren't pushing the datasheet limits, use whatever current works for your needs. The lower the current the less power and the longer the LED will last.
    #12 likes this.
  7. ian field
    Oct 27, 2012
    4,447
    791
    Usually the manufacturers data sheet indicates the current to use - if they're no-name unbranded parts; all you've got is guesswork.
    LEDs can't stand heat - if its running even perceptably warm, you're close to its limit.
  8. wayneh
    Sep 9, 2010
    12,384
    3,242
    While this is strictly true, it's worth pointing out that they are both nearly linear. The linear approximation is worthwhile in almost all situations.
    LEDs have a great property of not changing color (much) when dimmed. Incandescent bulbs change dramatically when dimmed.
  9. MrChips
    Oct 2, 2009
    12,635
    3,453
    I like to drive LEDs at the point where there is sufficient visibility and no more and that's in the 1-3mA range.
  10. cmartinez
    Jan 17, 2007
    3,698
    2,784
    #12 likes this.
  11. cmartinez
    Jan 17, 2007
    3,698
    2,784
    #12 likes this.
  12. WBahn
    Mar 31, 2012
    18,087
    4,917
    The last time this was posted it caught my attention because it looks like the voltage for the Green is actually curving back on itself and starts decreasing with increasing current. I thought that this was just an optical illusion, but I just used a triangle on it and it sure looks like it's going back to lower voltages.
  13. Stuntman
    Mar 28, 2011
    189
    50
    Of course so much of this is situational. I have one of those little battery operated LED tester, which is excellent for checking brightness at different currents.
    You may be surprised how much variation there is from color to color to get the same perceived brightness. You may also be surprised how little current it takes to get a very visible light.
  14. wayneh
    Sep 9, 2010
    12,384
    3,242
    Ditto. I usually aim for 2-5mA. More than that is an extravagance. Below 1mA, a 5mm LED looks dim.
  15. #12
    Nov 30, 2010
    16,689
    7,329
  16. cmartinez
    Jan 17, 2007
    3,698
    2,784
    Now that you mentioning it... yeah! it sure looks that way... but is there a commercially available green LED capable of consuming 60mA ?
  17. WBahn
    Mar 31, 2012
    18,087
    4,917
  18. Simon Larsen
    Feb 22, 2015
    31
    thanks for all the answers!
    cmartinez likes this.
