I am writing to a FRAM chip from a Propellor chip and have an intermittent fault on some boards.
Propellor chip is a P8X32A ...
http://cdn.sparkfun.com/datasheets/Dev/Propeller/Propeller-P8X32A-Datasheet-v1.4.0_1.pdf
Fram chip is a FM25V05 from cypress
http://www.cypress.com/file/41686/download.
I have attached my pin connections on the Fram.
I am testing a number of these, some pass some fail. I'm writing to the FRAM and reading back for a test.
So I put the oscilloscope on my clock signal into the FRAM to ensure that I was getting the correct clock signal and then suddenly the ones that fail start working when the oscilloscope leads are across the SPI_CLK0 and Ground on the PCB. If I take the leads away its fails again. I disconnect the power from the scope and the FRAM writes and reads ok also, but without the leads across the pins its fails.
A colleague tells me there is around 30pF capacitance in the scope leads so I tried a small 10pF capacitor on the SPI_CLK0 and GND of the FRAM chip and now the units that were failing are now passing. But this seems very strange to me on why this works. I could understand that if this was maybe a decoupling capacitor on the VDD and GND pins then sure as this is standard practice but why would a capacitor on the SPI_CLK pin cause this to work?
Any ideas on why this might be happening?
I should add that I have 2 other pic chips on the SPI bus but these dont appear to be affected from what I can see. I have attached a picture of this schematic also.
Kind Regards
Desmond
Kind Regards
Desmond
