Propeller clock
Discussion in 'Embedded Systems and Microcontrollers' started by lolmlol, Mar 1, 2014.
  1. lolmlol
    Oct 12, 2013
    I want to make a propeller clock using 8085 microprocessor. Is it posible and if yes then can you just give me some hints about it. I have basic knowledge about C, C++ languages and an 8085 simulator.
    It would be highly obliged if you help me.
    Thank You.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    The Completed Projects Forum is for Completed Projects only. It is meant to allow members to show plans for projects they built so other members can duplicate them if desired. New threads are also automatically moderated per Moderator review for this reason. Your thread does not belong in this forum, and was moved here.
  3. spinnaker
    Oct 29, 2009
    5,069
    1,176
    If you want to do it the hard way. A functioning 8085 would be a difficult enough project.
    Consider a mcu. Memory, peripherals everything you need in one package.
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Why use a 8085. Is this some kind of a educational project;) Anyway in such a project a 8085 alone will not be enough. You will alone with RAM and ROM need a timer like 8254(INTEL) and perhaps some PIP IC like the 8255 (INTEL)
    lolmlol likes this.
  5. paulfjujo
    Mar 6, 2014
    20
    hello,
    Did you allready decide the mechanical design ?
    rotative or oscillant ?
    Any years ago, i build a POV clock with a Voice coil of hard disqc
    Mechanic Base is oscillant arm at resonnance frequency..
    program in asm for a 16F876
    also, a Program in VB6 (OK with XP) to test the Mechanical and leds on arm
    with a texte displaying... use LPT port. to drive Voice coil and 8 leds
    http://paulfjujo.free.fr/HAPR/HAPR_index.htm
