propagation delay in logic gates
Discussion in 'General Electronics Chat' started by shiva kumar, Feb 3, 2012.
  1. shiva kumar
    Jun 27, 2008
    11
    Hi,,I have a query regarding the propagation delay in a gate,propagation delay is generally measured between 50 percent points on the input and output waveforms, why cannot we measure it between 20% or 80% points on the waveforms ? Is there any specific reason for opting 50% points ??
    Regards,
    Shiva.
  2. MrChips
    Oct 2, 2009
    12,636
    3,455
    In theory, if the rise times and fall times are the same then it does not matter where you choose. You have to pick a common point somewhere and the 50% point is the best because the slope is at the maximum.
    shiva kumar likes this.
  3. holnis
    Member
    Nov 25, 2011
    50
    It is possible to characterize various output transition times (e.g. 10%, 50%, and 90%) as a function of the input transition time, If it is needed.
    On the other hand and by definition: Propagation Delay, Is the time between a change in an input and a low to high (or high to low) change on the output. Measured from 50% point on input signal to 50% point on the output signal.
