propagation coefficient - Complex Numbers
Discussion in 'Homework Help' started by Kayne, Feb 23, 2011.
  1. Kayne
    Thread Starter Active Member
    Mar 19, 2009
    105
    Hi There,
    I am a little confused to how to work out a complex number that needs to be squared. For example
     y =a+jB = sqrt[(R+jwL) (G+jwC)]
    where
    R=0.2Ω/km
    L=1.1mH/km
    C=0.01uF/km
    G= Assume ≈ Negligible
    Freq = 50Hz
     = sqrt[(0.2+j2*Pi*50*1.1mH) (0+j2*Pi*50*0.01uF)]
     = sqrt[(0.2+j0.3455) (0+j3.141*10^-6)]
    I know that with complex numbers that to multiply the process is
    (ac-bd)+j(ad+bc)
    so
     = sqrt[(0.2*0)- (j0.3455*j3.141*10^-6) + (0.2*j3.141*10^-6)+(j0.3455*0)]
     = sqrt[(1.085*10^-6) + (628*10^-9)]
    Then If i square roots this the answer that I get is not correct. The answer that is given is
     = 0.29*10^-3 +j1.082*10^-3
    I am not sure what I am doing incorrect. So any guidance would be appricated.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    You have an error here. The expression (0.2+j0.3455) (0+j3.141*10^-6) written in the form (a+jb)(c+jd), you have a=0.2, b=0.3455 (not j0.3455), c=0 and d=3.141E-6.
    Therefore the expression equals -0.3455 \cdot 3.141 \cdot 10^{-6}+j \cdot (0.2 \cdot 3.141 \cdot 10^{-6})
    Can you take it from here?
  3. Kayne
    Mar 19, 2009
    105
    So
     = sqrt[(-1.085*10^{-6})+j(0.628*10^{-6})]
    then I take out the 10^{-6}
     = 10^{-6}sqrt[-1.085+j(0.628)]
    when i sovle this I still get the incorrect answer..... Still unclear sorry
    Is there any tutorials on this type of questions, that anyone knows of?
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Could you post the original question? I noticed that the quantities R, L and C are expressed per kilometer, so the size may differ.
    However, in the exercise's defence, for 1km, the correct answer is the one suggested and you mentioned. I, from my part, suggest you take more care of your number crunching.
    As an example, you forgot to change 10^{-6}\ to\ 10^{-3} when you took it out of the root.
  5. Kayne
    Mar 19, 2009
    105
    Hi Georacer,
    The question I have attached,
    I will have another look at the question and work though it again slowly.
    I guess what I am after is the steps that need to be taken so I can work this out on paper without using a computer program.
    Thanks for your help
  6. Kayne
    Mar 19, 2009
    105
    Georacer,
    I have tried to solve this with Matlab but the code I am using is incorrect.
    I have tried to input
    complex sqrt{(R+jwL)(G+jwC)} with the corresponding values above and there are errors..
    If this what you used to solve the problem? If so how did you enter it?
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    perhaps more like
    \gamma=sqrt (complex(R,\omega L)*complex(0,\omega C))
    but using the function 'sqrt(operand)'
    The '*' just denotes multiplication
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Here's an approximately equivalent sequence in Scilab ...
    Kayne likes this.
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
    Here is an exact Matlab code snippet:
    Code ( (Unknown Language)):
    1.
    2. R=0.2;
    3. L=1.1*10^(-3);
    4. C=0.01*10^(-6);
    5. G=0;
    6. f=50;
    7.
    8. omega=2*pi*f;
    9. y=sqrt((R+omega*L*i)*(G+omega*C*i))
    10.
    Kayne likes this.
  10. Kayne
    Mar 19, 2009
    105
    Thanks for that, I will try that code now and see how I go. This seems an easier way to solve these types of questions.
  11. Georacer
    Nov 25, 2009
    5,151
    1,266
    It won't help you in an exam, though. Better practice by hand.
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    It might also help if you remembered there is a polar form of complex numbers.
    For instance it can be helpful to use the polar form in the square root operation you have been considering. Convert the rectangular form to polar form and then use this realtionship
    \sqrt{(X\angle \theta)(Y\angle \phi )}=\sqrt{XY}\angle( \frac{\theta + \phi}{2})
