Proof Of Crammer's Rule For Determinents
Discussion in 'Math' started by Glenn Holland, Aug 9, 2015.
  1. Glenn Holland
    Dec 26, 2014
    361
    114
    I'm looking for the proof of Cramer's Rule for evaluating determinents or matrixes.
    Algebra books and sites give examples of how the rule is applied for solving simultaneous equations, but I would like to know the actual proof of how/why it works.
  2. WBahn
    Mar 31, 2012
    18,093
    4,920
    What do you mean by "proof of Cramer's Rule for evaluating determinents or matrixes"?
    What does it mean to "evaluate a matrix"?
    How are you using Cramer's Rule to evaluate a determinant?
  3. Glenn Holland
    Dec 26, 2014
    361
    114
    A rephrasing of my question is simply how/why does this rule provide a method of solving simultaneous equations.
  4. WBahn
    Mar 31, 2012
    18,093
    4,920
  5. tjohnson
    Dec 23, 2014
    618
    122
    For equations with only two unknown variables, the proof of Cramer's rule is fairly simple:
    (ax + by = e) * d = (dax + dby = de)<br />
(cx + dy = f) * -b = (-bcx - bdy = -bf)<br />
dax - bcx = (ad - bc)x = de - bf<br />
x = \frac{de - bf}{ad - bc} = \frac{\begin{bmatrix}e & b\\f & d\end{bmatrix}}{\begin{bmatrix}a & b\\c & d\end{bmatrix}}<br />
(ax + by = e) * -c = (-cax - cby = -ce)<br />
(cx + dy = f) * a = (acx + ady = af)<br />
ady - cby = (ad - bc)y = af - ce<br />
y = \frac{af - ce}{ad - bc} = \frac{\begin{bmatrix}a & e\\c & f\end{bmatrix}}{\begin{bmatrix}a & b\\c & d\end{bmatrix}}
    I had to dig out my math textbook to refresh my memory on this!:p
    EDIT: Corrected wrong math
  6. chukwuma
    Feb 5, 2013
    You can get a more general proof from Introduction to Calculus volume 2 by John Fritz and Richard Courant. Read through the second chapter. You'll find a proof of crammer's rule at the end of the chapter. The proof is satisfactorily rigorous, and applies to any n by n matrix
  7. Glenn Holland
    Dec 26, 2014
    361
    114
    Thanks.
    I hope "satisfactorily rigorous" doesn't mean I'm in for some root canal work, but I'll take a look.
    Is that book on line?
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    If you mean, can you buy it from Amazon, then yes.
    If you mean, can I download a PDF, then sadly, no it is not.
