1. unrooting
    Sep 25, 2009
    Need some assistance on a schoo project.
    I am needing to produce devcide that can configured the microcontroller and view uby use of a LCD and buton control. Along with that LCD display it must also communicate modbus over ethernet along with being power by ethernet. I am looking at a AT32UC3A112 (http://www.atmel.com/dyn/resources/prod_documents/32058S.pdf) as it has the ethernet mac builtin, however I was looking to see if you all had another other suggestions. Using a 8bit with an ethernet controller. But cost is the biggest factor for this project.
    Also in terms of LCD which protocoldo you prefer?
