Project works on breadboard but not PCB??
Discussion in 'The Projects Forum' started by Tanters, Aug 23, 2012.
  1. Tanters
    May 30, 2012
    Hi, I'm working on building a meter to essentially measure the conductivity between a set of probes. When I had the circuit setup on a breadboard it worked fine but when I tried switching the circuit onto the PCB I had designed I was unable to get the same results.
    I'm attaching pictures of the schematic and board layout used.
    - I am using and arduino UNO as the MCU. A0 and A1 on the schematic represent the analog inputs.
    - the GND's on the schematic all run to the GND of the UNO
    - P1 and P2 are the outer set of probes
    - P3 and P4 are the inner set of probes
    - the center UC2610 portion of the circuit is used for measuring current and the other UC2610 is used for measuring voltage
    Any help would be greatly appreciated! Thanks!
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    What/how is it not working compared to before?
    Not working at all?
    Not the right output?
    Have you checked each wire/trace on your PCB and protoboard to make sure they match?
  3. nerdegutta
    Dec 15, 2009
    2,565
    805
    Are you using and SMD cap for C3?
    Are you sure PIN1 is connected to GND on the 555?
    ED: It is ....
  4. tracecom
    Apr 16, 2010
    3,878
    1,396
    A suggestion for the future: identify pin 1 on all IC's on the PCB. People do it differently, but here's one way (actually, it's two ways.) :)
  5. Tanters
    May 30, 2012
    When it was setup on the breadboard it worked perfectly. but when I switched the parts over to the PCB P1 had no voltage supplied to it.
    I've checked over all the traces yes.
  6. Tanters
    May 30, 2012
    Yes C3 is a SMD.
    And ya pin 1 on the 555 was connected to ground when i had it setup on the breadboard.
  7. tracecom
    Apr 16, 2010
    3,878
    1,396
    I am concerned about pin 5 on the 555 being connected directly to ground. What is the purpose of that? Are you sure that pin 5 shouldn't be connected through C3 to ground as opposed to being connected to pin 2?
    Tanters likes this.
  8. Tanters
    May 30, 2012
    Oh I see what you mean. Ill try fixing that and see if that helps thanks!
  9. derfisherman
    Feb 20, 2012
    ....and he never returned.......
  10. tracecom
    Apr 16, 2010
    3,878
    1,396
    Yep...I guess we'll never know.
  11. absf
    Dec 29, 2010
    1,493
    374
    Which means either he has solved the problem or he has given up..
    Just give him one more week.
    Allen
