Project - To design a simple temperature sensor help ..!
Discussion in 'Homework Help' started by Giggabyte, Oct 6, 2008.
  1. Giggabyte
    Sep 19, 2008
    15
    Im looking to design a simple temperature sensor which when heat is detected then a lamb or buzzer is activated . Would anyone have a schematic diagram with the components . I was thinking of a low coefficient temperature sensor which when it detects a higher temperature threshold would increase its resistance thereby turning on a transistor , then a 741 op amp..etecetera..! cheers
  2. Giggabyte
    Sep 19, 2008
    15
    Im not sure whethether to put a fern on but id like a guidline to break my circuit into parts ...!
  3. oji4real
    Jun 7, 2009
    i was woundering if u happened to complete the project on temperature sensor
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Why not use a thermostat?
