Project: Textool SOIC Socket_DIP Adapter
Discussion in 'The Projects Forum' started by jpanhalt, Jan 8, 2009.
  1. jpanhalt
    Thread Starter AAC Fanatic!
    Jan 18, 2008
    5,699
    909
    3M makes a device called a burn-in socket under the brand name of Textool. The datasheet available on the 3M site does not show the pinout, but that information is available from technical service.
    I needed a socket for programming 8-pin SOIC microprocessors without using ICSP . One can be made using the Textool for about $20.
    Here is a picture of the competed gadget, an image of the PCB, and the Eagle .brd file. I have also attached the additional datasheet from 3M that shows the pinouts. I used a 1/32 PCB so as not to limit the lengths of the header pins too much. I can provide the Eagle .lbr for the Textool device if anyone wants. Just PM me.
    John
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Looks nicely done - but don't forget the solder.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    What you see is probably an optical artifact from too much conformal coating applied all at once. I wanted a heavy coating, and after masking, it was hard to get into all the nooks and crannies.
    John
    Edit: I think I see the areas you are referring to. They still work.
  4. alberss
    Oct 14, 2009
    I just received my 3M Textool with part # 208-7391. It's a SOIC PGM/Burnin SOIC ZIF socket. I am having a problem with it (maybe it's just me..): I can't seem to get on of my Attiny 85 20PU SOIC's in the socket! Is there a special way you should insert the chips?
    I like your 'hany' conversion board. Do you have a 1:1 pdf file of the print layout for me?
    Thanks,
    Stephen
  5. alberss
    Oct 14, 2009
