Hello all,
This project uses BasicStamp 2P (also you can use PIC) to interface with a DS1307, SHT15, JP Module and 16x4 LCD display. Code used is standard PBasic 2.5, it should work on most BasicStamp chips.
The project is a data logger demonstration program. It can record temperature and humidity data to MMC/SD card with date and time. Press the temperature unit select button switch to select Celsius or Fahrenheit. The data can be processed to the virtual XY chart or Polar Chart through the website ( www.jianpingusa.com/jpchart ).
Components:
1) Basic Stamp 2P
Manufactory: www.parallax.com
Datasheet: http://www.parallax.com/tabid/440/Default.aspx
2) DS1307
Manufactory: www.maxim-ic.com ,
Datasheet: http://datasheets.maxim-ic.com/en/ds/DS1307.pdf
3) SHT15
Manufactory: www.sensirion.com
Datasheet: www.sensirion.com/en/pdf/product_information/Data_Sheet_humidity_sensor_SHT1x_SHT7x_E.pdf
4) JP Module
Manufactory: www.jianpingusa.com
Datasheet: http://www.jianpingusa.com/datasheet/JP%20Module%20Instruction.pdf
5) 16x4 LCD Display (CM1644 series)
Manufactory: http://www.femacorp.com/
Datasheet: http://www.femacorp.com/Products/LCD/Character%20Modules/Character%20Modules%20Index.htm
Data processed website:
1) schematic
2) code
www.OldSpring.110mb.com/thcode.txt
3) Project photo
4) XY Chart
5) Polar Chart
6) Video Link: http://www.youtube.com/watch?v=CY6NPmKLrRc
Author of this project: OldSpring
Thanks to AllAboutCircuits team and all forum users.
For more projects @ OldSpring Project WebSite
www.OldSpring.vndv.com
Components:
1) Basic Stamp 2P
2) DS1307
3) SHT15
4) JP Module
1) schematic
2) code
3) Project photo
4) XY Chart
5) Polar Chart
