project router in microcontroller 16f887
Discussion in 'Embedded Systems and Microcontrollers' started by zemzi, Dec 16, 2011.
  1. zemzi
    Dec 14, 2011
    Here is the text of my project, can someone help how to solve this?
    To program the PIC to work as a Super Router, and reading the serial
    port frame, forwards them to the standard, or rejected. The next message
    First Destination MAC, 6 bytes fixed - variable value for each frame
    Second TTL, 1 byte fixed - variable value for each frame
    Third Length, 1 byte fixed - variable value for each frame
    4th Data, [1, 16] bytes - variable value, variable length for each frame
    5th Error Code, 1 byte fixed - sum of all units in the field 1-4
    And process the PIC as follows:
    First Checking the MAC address.
    - If it is rejected and the LCD display reads in two lines - "Primiv
    ramka sto ne e za mene ".
    - If it is addressed, go to step 2
    Second Checking the Error Code.
    - If the frame is error, rejecting the LCD screen and write in two rows -
    "Primiv ramka sto gresna".
    - If the frame is not an error, go to step 3
    Third Check the TTL.
    - If the TTL is 0, the frame is discarded and the LCD display reads in two rows -
    "Primiv ramka sto TTL = 0".
    - If TTL> 0, go to step 4.
    4th Creating a framework for sending.
    - In the Dest. MAC value is entered as DestMac own arbitrary will
    create it as a variable
    - TTL field is reduced by 1 from the received frame
    - Length field remains the same
    - Data remains the same field
    - Calculate new value for the Error Code field
    After creating the frame, it sends the serial port, and write the first row of the LCD
    - "Prativ ramka:", second row area Data
    After sending, wait for a new framework. Assume that in the meantime not to arrive
    new framework.
