With this project, you can use the speakers you like. 4Ohm speakers will deliver more power for the same operating voltage, since more current is needed. This project already uses 4Ohm speakers, so any of these are supported without the need of doing recalculations. Of course, I have the enclosure calculated for use with Visaton FR10 4OHM speakers. You will probably have to calculate the enclosures for your speakers, if you choose different ones.I think the "Quatour" is more like what I need, thanks. A bit of tone control etc. will do the job very nicely. I will buy decent speakers to match.
No problem there, since the project requires a minimum of 9.80V. Just make sure that the voltage doesn't get lower than that (probably it won't, since you are using the battery cells from your boat).I see the project requires 13.5V, will this be an issue if I supply 12V? I can use 2X12V Gelled Cells and regulate the voltage but would prefer not to.
