Louie,
You may not have seen it, but I posted the values that you should use in Audioguru's 555 timer circuit in order to get 1/2 second between switching to the next LED
There is one additional capacitor that was not addressed attached from pin 5 to ground; normally this is an 0.001uF to 0.01uF cap - however, you can also use a 0.1uF cap on it.
OK, you need to find out what your LEDs really drop as far as voltage. That number can vary quite a bit from batch to batch. Let's test several of them and find out.
Your LEDs are rated for 20mA at somewhere between 2.8v and 3.6v. You have a 5v supply. Let's calculate a "safe" value of resistor to use in testing them.
The LEAST voltage they will drop is 2.8. Let's subtract that from your power supply voltage:
5V - 2.8V = 2.2V
Now we need to determine what value of resistor will guarantee a maximum of 20mA current across 2.2V:
R = E / I
R = 2.2V / 20mA
R = 2.2 / 0.02
R = 110 Ohms
So, if you connect a 110 Ohm resistor in series with your LEDs that you are testing with a 5V power supply, you should not exceed their rated 20mA current.
To make sure, use your multimeter in series with the 110 Ohm resistor and and the LED across the power supply to measure the current; use the 200mA range.
After you've measured the current, set your multimeter to 5v or 10v range, and connect the LED in series with the 110 Ohm resistor across your power supply. Measure the voltage drop across the LED. It should fall within the range of 2.8 to 3.6 volts.
You should measure several more LEDs to make sure this is pretty consistent. Use the lowest reading you measured, and return to the part where the "safe" resistor was determined above; this time using the lowest measured voltage across the LEDs.
5V - 2.8V = 2.2V
R = E / I
R = 2.2V / 20mA
R = 2.2 / 0.02
R = 110 Ohms
