There are lots of different epoxies. I suspect the things you are most interested in are: 1) glass transition temp (Tg); 2) viscosity; and 3) curing time. Some epoxies require post cure heating to reach their designed properties. I suspect strength is not a big issue for you -- almost any epoxy should be adequate. Anyway, the ebay listing doesn't give any specifications.
I have an early appointment and have to leave soon. What I was describing was making an epoxy tube. Modelers need to cast and form epoxy like that for a variety of parts.
John
Edit: I think a high-temp laminating epoxy would better fit your needs than one designed for potting.
John
