This is a small board for plugging into solderless breadboards to give a visual indication of voltages for project debugging.
There are 5 pins, one common and the others connected to the 4 pairs of LEDs. The pairs of LEDS are wired in reverse parallel so that it can be used as common anode or common cathode.
All the components are 0603 size SMD components and the board can be made and soldered using your favourite method. I used UV exposure and used solder paste and a hot plate for the SMDs.
In action:
Most of the parts are not properly aligned, but works fine.
Schematic:
PCB layout:
In action:
Schematic:
PCB layout:
