project in voltage divider BJT
Discussion in 'The Projects Forum' started by muad, Dec 18, 2015.
Thread Status:
Not open for further replies.
  1. muad
    Dec 18, 2015
    6
    THE AIM OF THE PROJECT TO GET Ic OF 10mA WITH CLASS A ( STABLE Q-POINT ) .
    WHICH VALUES ARE RECOMMENDED TO BE TAKEN TO GET AN Ic of 10mA ?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What transistor? What supply voltage? What temperature range? Why are you shouting? Why isn't this posted in the homework forum?
  3. crutschow
    Mar 14, 2008
    13,475
    3,362
    Sounds like this is a project that should be in the homework section.
    The recommended values are those you calculate to get the desired current and stability in the appropriate circuit configured with your selected transistor.
    Since we don't do your homework for you here, this should help get you started.
  4. muad
    Dec 18, 2015
    6
    ok thank you
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
Thread Status:
