Project idea for school
Discussion in 'The Projects Forum' started by xxxyyyba, Oct 13, 2014.
  1. xxxyyyba
    Aug 7, 2012
    249
    Hi!
    I have to build some circuit using operational amplifiers. Any suggestion? I found on web few projects, like Cell phone detector, water level controller etc. but I's not interesting for me :) It may consist of microcontrollers too. Thanks in advance.
  2. wayneh
    Sep 9, 2010
    12,377
    3,230
    Well there's the rub. What sort of thing WOULD interest you? There's no limit to the projects out there. The key is finding something that inspires you. Radio? Solar power? Magnets? Computer logic? Robotics and sensing?
    xxxyyyba likes this.
  3. ISB123
    May 21, 2014
    1,240
    531
    You could build low power transistor amplifier.
  4. xxxyyyba
    Aug 7, 2012
    249
    @wayneh,
    It shouldn't be so sophisticated, like robotics :) Circuit must contain at least one opamp and it should't be so complicated.
  5. wayneh
    Sep 9, 2010
    12,377
    3,230
    That's fine - complex systems like a robot are built up from smaller components. You might have an op-amp that helps sense a robot's surroundings, for instance. Maybe a thermometer or thermostat. Line-following robots are pretty darn simple.
    I'm not advocating for any particular project, just that you should think about what general area might interest you and then folks here might have some thoughts.
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    Transmission of music using IR or white LED.
  7. xxxyyyba
    Aug 7, 2012
    249
    I would like to build current source. Can you suggest me some good implementation?
  8. ISB123
    May 21, 2014
    1,240
    531
  9. xxxyyyba
    Aug 7, 2012
    249
    Zahvaljujem :)
