project help
Discussion in 'The Projects Forum' started by fkuk, Dec 30, 2009.
  1. fkuk
    Dec 17, 2009
    7
    the lm3916 is slightly messed up the program did not have 18 pin chip
    this is two halfs of my project
    induvidually the both work but
    joining together im having problems
    when nothing is connectted to pin 5 all leds are on
    when pin 5 is connect to ground all led are off
    when pin 5 is connected to top half of the output pins (one above capacitor) all leds are on
    when pin 5 is connected to bottom of output pins below cap all leds off
    when a 20k resistor is attached to pin 5 to ground
    when nothing is connectted to pin 5 all leds are off
    can someone guide me in the correct direction to get this thing working
  2. fkuk
    Dec 17, 2009
    7
    when i coonect headphones to the outputs of microphone rig the sound is high
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    Working to do what?
  4. fkuk
    Dec 17, 2009
    7
    what do you mean
    do you mean this sentence
    by that i mean when pin 5 is connected somehow to microphone and amplifier
    when there is silence all leds are off
    and when there is noise the lights bounce up and down
