project help !
Discussion in 'The Projects Forum' started by ali8tor, Sep 9, 2014.
  1. ali8tor
    May 29, 2012
    43
    hi im currently working on a project where I need my circuit to decrease and increase in speed when a state is true or false i don't want to do this through micro controllers is there an ic out there i could use with a bit of logic?
    any advice will be appreciated
    thankyou
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Are you looking for a voltage to frequency convertor? Or are you talking about a motor or something similar?
  3. ali8tor
    May 29, 2012
    43
    it would lean towards a motor for example if my switch is closed my car would travel at 60 km and if its open it would reduce to 5km
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  5. pwdixon
    Member
    Oct 11, 2012
    488
    56
    Sounds like a big solenoid connected to your accelerator pedal but you really need to give more detail of what you are really trying to do for a more sensible response I'm afraid.
