Project Help please!!
Discussion in 'General Electronics Chat' started by Lee BMW, Feb 17, 2011.
  1. Lee BMW
    Feb 17, 2011
    9
    Hey Guys
    Newbie to the forum just looking for some help please, you all look pretty knowledgeable so thought itd be a good place to start :)
    Basically what I want to do is run a car washer jet/pump system (off the 12v car battery) in some way that will allow me to flick a switch, then the washer jets will run for say 5 seconds on, 20 seconds off, 5 seconds on, 20 seconds off, in an unlimited cycle until i flick the switch off... :)
    (If anyone is interested its to go into a drift car with washer jets in the rear arches to keep the tyres cool while drifting on sunny days at Santa Pod raceway :))
    I'm a pretty competent solderer and I'm good with car audio installation etc, but this is a bit out of my league!!
    Thanks in advance!!
  2. t06afre
    May 11, 2009
    5,939
    1,222
    I guess this can de done with a LM555 controlling a relay. That activate the jet pump. We have forums rules regarding auto modifications. But I guess this will OK. As it is more or less a passive system. But the the mods have to decide
    http://forum.allaboutcircuits.com/showthread.php?t=40361
  3. edgetrigger
    Member
    Dec 19, 2010
    133
    19
    can i drift alongwith you if i build the system for you ! I live in bangalore and i need atleast a weeks notice to backpack!
  4. Lee BMW
    Feb 17, 2011
    9
    1. Modifications to the ECU or engine sensors are not topics for discussion. Too many safety and legal issues come up. Air quality and safety trump performance.
    Its not modifying the ECU or sensors so thats all good :)
    2. Any homemade wiring modifications to signal or head lighting, or penetrations through the fiewall are not for discussion. The lighting function is to too critical for non-approved wiring and connectors. Many safety issues are involved. Preventing chafing in wires passing through driver-made holes is impossible to guarantee.
    Not got anything to do with lighting :)
    3. Add-on items that exist in the passenger spaces is generally okay. Exceptions are lights flashing to music and similar driver distractions. Assurances that the color organ will only get operated while sitting still is not credible.
    Doesnt go anything with music/lights and it wont distract the driver as its switched on before track time and after track time :)
    Hopefully the mods allow it :)
  5. Lee BMW
    Feb 17, 2011
    9
    Honestly mate I'm a noooooooob with this kind of electronics lol... Can you go into a bit more depth pleasE? :)
  6. Lee BMW
    Feb 17, 2011
    9
    Yeah sure why not :p lol
  7. edgetrigger
    Member
    Dec 19, 2010
    133
    19
    Thanks dude! i'm not lucky i suppose. I thought you were in usa, for uk i dont have the visa. anyways i will courier you the ckt
  8. t06afre
    May 11, 2009
    5,939
    1,222
    LM555 is a very popular timing circuit for hobbyist. You can read about it here http://en.wikipedia.org/wiki/555_timer_IC. Since you are using it in a car. I will not recommend the CMOS version. As the standard version can handle supply voltages somewhat higher than the CMOS version. This is at least true for the National Semiconductor version. It is produced by many vendors. Here is the datasheet http://www.national.com/ds/LM/LM555.pdf Look for ASTABLE OPERATION
  9. Jaguarjoe
    Apr 7, 2010
    770
    90
    A $3 Picaxe 08M microcontroller and 20 minutes of simple programming would do this with ease. These are much more stable and less prone to false triggering than a 555. Join the Picaxe forum and bounce this off of them. They'd love to help.
  10. Lee BMW
    Feb 17, 2011
    9
    Ok I think im getting the idea now, slowly :p
    So basically the legs of the LM555 would have to be wired in a way as such to do what I want it to right?
  11. nerdegutta
    Dec 15, 2009
    2,567
    806
    Do you have some spec's on the washer jet/ pump? What will you be pumping?
    I've heard of a similar arrangement, where they sprayed oil on the tires, just to get them slippery so they could to this:
    http://www.youtube.com/watch?v=inFFLiSe-nc
  12. t06afre
    May 11, 2009
    5,939
    1,222
    The 3$ Pic axe may very quickly be quite more costly. Like need of a USB to serial cable plus plus. Although working with controllers are cool. And I would have used it my self, but no PICaxe. In this case the OP says he is a n00b. So I think a simple solution using a 555 circuit will be best in this case. No need for voltage regulators etc.
    @Nerdegutta that was a "blodharry" video:eek:
  13. Lee BMW
    Feb 17, 2011
    9
    what specs do you need mate?
    Just water to be pumped to keep the tyres cool :)
  14. nerdegutta
    Dec 15, 2009
    2,567
    806
    Power and Ampere... I'm guessing 12v since it is a car. But I can't guess the Ampere...
    Maybe you have a picture of the pump, or better, a datasheet...
    @t06afre:
    It sure is a "blodharry" video. I believe the guys in the video are some Swedish rednecks...:rolleyes:
    Lee BMW likes this.
  15. Lee BMW
    Feb 17, 2011
    9
    I'll get it a.s.a.p.
    Thanks so much for your help :)
  16. Lee BMW
    Feb 17, 2011
    9
    When i get the details will someone be able to help me with a wiring diagram/how to wire it all up and the parts that I will need?
  17. nerdegutta
    Dec 15, 2009
    2,567
    806
    I think there's somebody that are willing to give it a try. As long as the moderators think it's ok.
  18. Lee BMW
    Feb 17, 2011
    9
    Cool Cool :)
    I'm trying to get the specs at the moment :)
  19. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It is a bit strange, but doesn't seem to get into a safety issue.
