Project Help - Design of an op-amp circuit.
Discussion in 'The Projects Forum' started by Ricky Sum, May 6, 2016.
  1. Ricky Sum
    May 6, 2016
    13
    Hi Everyone I got a project but I dont understand and also where to start with.
    DESIGN OF AN OP-AMP CIRCUITS
    Given that the pressure sensor produces an output voltage (Vs : sensor output voltage) according to the equation Vs = (P x 0.131 )+ 1.683. This equation can be expressed in
    terms of pressure (P) versus sensor voltage (Vs). ie. P = (Vs - 1.683)/0.131 You are to design the amplifier circuit for this sensor using any combination of
    inverting amplifiers, non-inverting amplifiers, summing amplifiers together with a 1V
    reference voltage source. The two input signals of this circuit are sensor voltage (Vs ) and an 1V reference
    source (Vref ) and the circuit should produce an output voltage (Vo) indicating the pressure (psi) according to the equation Vo = P (psi)
    i.e When P = 0 psi , Vo = 0V and P = 10 psi, Vo = 10V. P = -10 psi, Vo = -10V.
  2. Bordodynov
    May 20, 2015
    670
    194
    I decided to have fun.
    See
    Ricky Sum, frpr666 and wayneh like this.
  3. Dodgydave
    Jun 22, 2012
    5,150
    769
    What sensor are you using, which op amps, voltage, pressure range?
  4. Ricky Sum
    May 6, 2016
    13
    Normal pressure sensor
    Hi, are this is the step of doing this project.
  5. dannyf
    Sep 13, 2015
    2,196
    417
    It looks like a summer, and a gain stage, at a minimum.
    All you need to do is to break that equation into formats that can be handled by a typical opamp block.
  6. Ricky Sum
    May 6, 2016
    13
    How can break the equation
  7. Ricky Sum
    May 6, 2016
    13
    How do you break the equation?
  8. Alec_t
    Sep 17, 2013
    5,971
    1,135
  9. AlbertHall
    Jun 4, 2014
    2,262
    448
    This pressure sensor reads down to -10psi? Given that a vacuum is 0psi, how do you get lower pressure than that?
  10. wayneh
    Sep 9, 2010
    12,381
    3,236
    The "g" for gauge in psig is often dropped. Endless confusion versus psia, "a" for absolute.
