Project Help - a bioreactor and two pinch valves.
Discussion in 'The Projects Forum' started by Zooz, Nov 26, 2015.
  1. Zooz
    Nov 24, 2015
    7
    I need to add a circulation line to a bioreactor and control the line with two pinch valves. The valves I will use are the following: http://www.coleparmer.com/Product/T...ve_12_VDC_1_16_ID_x_1_8_OD_tubing/EW-98302-42
    Controlling the valves will be through a computer. I will need to use data acquisition and LabView. I will need to use a TTL switch to make the valves TTL. The valve should open when the digital out pin is set high (5V) and close when the digital output pin is set low (0V). I need help with choosing the right switch that can operate with the valves. I hope you guys can help me with this..
  2. Picbuster
    Member
    Dec 2, 2013
    391
    53
    a: place a diode over the solenoid.
    b: use a Nmosfet able to run 30V
    c: place a resistor 47K between gate and source. ( source to gnd)
    d: connect resistor 1K between TTL output and gate.
    e: connect drain to anode of diode
    f: Power - to gnd +12V to kathode of diode.
    Zooz likes this.
  3. KeepItSimpleStupid
    Mar 4, 2014
    1,271
    224
    Zooz likes this.
  4. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Any MOSFETS used must be of the 'logic-level' type to ensure that 5V on the gate will switch them fully on.
    Zooz likes this.
  5. mcgyvr
    Oct 15, 2009
    4,789
    974
    how many posts are you going to start on the same subject?
    This is #3 now..
