Project: Gang Programmer for UCD9240
Discussion in 'The Completed Projects Collection' started by wilbur.harvey, Nov 16, 2008.
  1. wilbur.harvey
    Nov 16, 2008
    These are the schematics (OrCAD Capture 16.2) and the PCB file (Artwork + Allegro 16.2 .brd file) for a 4-chip UCD9240 programming board.
    I uses the standard TI USB to PMBus dongle.
    It is not quite finished
    1) Needs the proper resistor values to set unique I2C addresses for each chip
    2) Needs a ZIF socket for the chips
    3) Needs a proper power connector.
    It is intended to run from a 3.3V regulated power supply
  2. changling_123
    Feb 23, 2009
    i have a project with ucd 9240 so i hope you shall it with me ,thank you very much!
