Happy New Year all:
I've searched through the forum without luck at this time. I am in the planning stages of building a project requiring a 12 hour timer. This timer will activate a relay for about 2 seconds every 12 hours. I was thinking about using a 555 timer, but not sure if the timer and caps can handle the 12 hour 0V time with any decent degree of accuracy. I don't need to-the-second accuracy, but would like the timer to be within 5-10 minutes. However, at that rate, the activation time may end up being waaaaay off after a week or so.
The other alternative would be to use a mechanical timer. As the mechanical timer would have an on cycle of no less than 10-15 minutes, I would need something that would only pulse the relay for no more than 2 seconds and then go back to 0V after the timer supplies power.
Thanks,
John
Thanks,
John
