Project: Flasher circuit
Discussion in 'The Completed Projects Collection' started by amey, Nov 4, 2007.
  1. amey
    Nov 4, 2007
    NOVEMBER 2002 ELECTRONICS FOR YOU
    ASHOK K. DOCTOR
    A flashing beacon has many uses. It
    can be employed as a distress signal
    on highways or as a direction
    pointer for parking lots, hospitals, hotels,
    etc. Here we present a flashing beacon
    that uses well-known regulator IC LM317T.
    As LM317T regulator can deliver more than
    1 amp. A small 12V, 10W bulb with a
    high-quality reflector can serve as a good
    visible blinker.
    A 12-15V, 1A DC supply is connected
    to the input pin of the IC. A 12V, 10W
    bulb and a combination of resistors and
    capacitors are connected between the output
    pin and ADJ pin of the IC as shown in
    S.C. DWIVEDI
    the figure. The IC is provided
    with an aluminium
    heat-sink to dissipate the
    heat generated while delivering
    full current. Since the
    IC has an inbuilt switch-on
    current limiter, it extends
    the bulb life.
    For the shown values
    of resistors and capacitors,
    the bulb flashes at approximately
    4 cycles per second.
    The number of flashes depends
    on the charge-discharge
    time of the capacitors.
    Different values of resistors and capacitors
    can be used to increase or decrease the number of flashes.
    This circuit costs around Rs 50.-
  2. cumesoftware
    Apr 27, 2007
    1,330
    11
    So, you are using the "adj" pin to give some positive feedback, behaving the LM317 like an oscillator?
  3. SICKNESS1
    Nov 16, 2007
    Thanks You Very Much
  4. ohm_5000
    Dec 22, 2007
    thank you very much
  5. narced
    Dec 22, 2007
    thanks a lot!
  6. Legi0nare
    Jul 27, 2008
    Thnx for the circuit
  7. tallht
    Jul 30, 2008
    thanks a lot
  8. Giggabyte
    Member
    Sep 19, 2008
    15
    this is good .
  9. u.chinonso
    Sep 29, 2008
    this is good
  10. Bernard
    Aug 7, 2008
    4,230
    412
    Just left another Thread " How many LED 's can run from 12V. Here about 150, 50strings of 3 ea.+ 50 150Ω resistors. Nice circuit.
  11. jj_alukkas
    Distinguished Member
    Jan 8, 2009
    751
    5
    Why dont you try using an automobile turn indicator relay??? It can run heavy loads and needs nothing more than a single component.. No heatsinks and no mess.. just 2 terminals on a box
  12. vinay soni
    Feb 16, 2009
    nice project
