Project enclosure
Discussion in 'The Projects Forum' started by odm4286, Jul 22, 2013.
  1. odm4286
    Thread Starter Active Member
    Sep 20, 2009
    155
    5
    Hello everyone, I have a quick question about project enclosures. I've built most of this simply dc power supply
    http://www.popsci.com/diy/article/2009-12/build-simple-dc-power-supply
    and now I need to make an enclosure to finish it up. I was thinking about using plexiglass and actually found an old picture frame that someone threw out. Would it be safe to to use the material found on the picture frame? Its definitely some type of acrylic sheet but I'm not sure which type.
  2. Johann
    Nov 27, 2006
    190
    30
    Hi ODB4286,
    For this type of project, your salvaged plexiglass will do just fine! Just keep all the mains wiring safely inside so that no-one can get electrocuted!
  3. wayneh
    Sep 9, 2010
    12,371
    3,224
    You may need vent holes to allow a bit of cooling.
  4. mcgyvr
    Oct 15, 2009
    4,787
    973
    And of course "if" a fire starts in your power supply the plastic is only going to fuel it further. Metal is a better choice.
    And yes as wayneh said.. You'd better ensure that you aren't trapping any heat your power supply is dissipating. A fan is never a bad idea as well as adequate ventilation holes.
  5. bance
    Member
    Aug 11, 2012
    315
    34
    I'd probably add some short circuit, over voltage/current protection to that circuit as well....
    HTH Steve.
  6. LDC3
    Apr 27, 2013
    920
    160
    You could use this to connect the power cord.
  7. GopherT
    Nov 23, 2012
    6,303
    4,021
    Plexiglas, acrylic and lucite are all versions of poly methyl methacrylate. Once overheated, they will depolymerization and burn well. You are better off with a polymer like polycarbonate, PVC, or any polymers with flame retardants compounded into the plastic.
    Best and easiest is metal. Use an old ATX computer power supply. They are about the size you need and already have the Mains connector and fuse build into the box. Fire and electrocution are the biggest concerns of this hobby - both are deadly.
  8. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    And grounded to boot!;)
    Max.
    GopherT likes this.
  9. Markd77
    Sep 7, 2009
    2,803
    594
    If you have a hot air gun you might be able to make a case just like the picture on that page.
  10. wayneh
    Sep 9, 2010
    12,371
    3,224
    And already filled with a good power supply. ;)
