Project: dsPIC-based Single Chip MP3 Player
Discussion in 'The Projects Forum' started by fernan82, Apr 20, 2014.
  1. fernan82
    Apr 19, 2014
    26
    9
    Here's the project:
    http://mypod.fernansoft.com
    It's a working project but it sure can be improved. Feedback is appreciated.
    Fernan
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Please read the rules of the Completed Projects forum.
    This project has sat in limbo basically because it didn't meet the above requirements. If you want to resubmit this entry please rework the entry to meet the requirements, then drop one of the moderators a PM pointing to it. If it is acceptable a moderator can move it back to the Completed Projects forum and clean up notices and suggestions (making them invisible).
    All documents must be hosted locally. AAC allows for attachments and albums, use them. You Tube video links allowed, but they in no way constitute proper documentation.
    This post will self destruct if you use this thread to update your entry.
    The moderators can also insert posts ahead of other peoples if you need more than one post in sequence to do it right.
  3. Little Ghostman
    Member
    Jan 1, 2014
    294
    97
    I would like to convert that to run of either of these boards :D
    The Giant Gecko has mammoth memory on board (1meg) and is CORTEX3 (I think?) and the wonder Gecko is CORTEX4 with FPU and DSP engine. When I get time I am going to do some audio stuff with these boards.
    Nice project by the way
