Project: Discrete Master-Slave Flip flop
Discussion in 'The Completed Projects Collection' started by hobbyist, Sep 5, 2008.
  1. hobbyist
    Thread Starter Distinguished Member
    Aug 10, 2008
    774
    65
    Hi
    This is a circuit I made long time ago and I wrote a paper about it.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Interesting... For what grade (college or high school) in school?
  3. hobbyist
    Aug 10, 2008
    774
    65
    No, it wasn't for any homework or anything, it was just for my hobby interests, in learning basic electronic circuits design.
    I took 2 homestudy courses from NRI back some time ago, late 80's early 90's, ,"Basic Electronics" and "Electronics Circuit Design" course.
    But before that,all my learning was, getting one of those 160 in one electronics labs. from radio shack, then building the circuits instructed in the book.
    Then exp. changing components and recording the results until I had some understanding of why it worked the way it did.
    To make a toggle flip flop, on the schematic, I show a dotted line, this is a connection, from the output of the transistor Q8 marked 'Q
    (Not Q) to the transistor Q1 base input marked Data.
    Then toggle the switch marked clock.
    Hope this helps.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    I notice the article said something about 100ma? I believe you meant 100ua?
  5. hobbyist
    Aug 10, 2008
    774
    65
    Hi Bill
    I just took another ammeter measurement,
    it idles at around 90ma. then when i depress the data switch and clock, it jumps to around 117ma.
    I guess back then when I was just learning about electronics I thought that 100ma. was small, but actually it is alot of current drain especially on a battery.
    I think most of the current drain is through the 470 ohms on the rs flip flops.
  6. Venkatesh G.M
    Nov 1, 2008
    sir, i want some guidence for vlsi projects can u help me ?
  7. hobbyist
    Aug 10, 2008
    774
    65
    If VLSI is "very large scale integration" I can't help you there, because I don't know anything about IC's ,my hobby in electronics, Is designing using discrete components.
    However quite some time ago, I did make a very large scale integrated circuit using all transistors and discrete components, it was 2'x2' square, it was a 64 bit ram with a 8x8 led grid, more or less a character generator.
    The ram was made using scr's had to make about 5 power supplies, but all in all it worked really good. I learned a lot about digital logic through that project.
    I think your question would be answered a lot quicker if you posted it in it's own thread in the "projects forum" That way the people can view it more easier to adress your issue.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    Hobbyist, I admire your interest in circuit design. I'm a retired EE, and was a circuit designer for my entire career (still am, for that matter).
    Your design is interesting. If you are wondering why the current is so high, you might want to consider that the current through the emitter followers Q2, Q3, Q5, and Q6 (when they are on) is limited only by the beta of the transistors and the base currents through the 100k resistors. This has great potential for smoke.:eek:
  9. hobbyist
    Aug 10, 2008
    774
    65
    Thanks Ron H.
    Thankyou for the complement.
    I see what you are saying, the transistors are probably going into saturation big time. to remedy this I would need to put a base resistor to ground and bias the transistors in the active region enough to get the appropriate output signal, and maybe a resistor in the emitter lead for temp. stabilization, to get rid of some of the Beta dependancy.
