project delay start for 10 second and automatic of after 15-30 second
Discussion in 'The Projects Forum' started by Cgau, Nov 25, 2013.
  1. Cgau
    Nov 25, 2013
    5
    hye..can someone help me how to design a circuit in which when we switch on the circuit,it do not immediately start then it will start after 5 sec and then it will stop back after 15-30 seconds after it moves..
  2. R!f@@
    Apr 2, 2009
    8,789
    771
    What do you wanna use ?
    A 555 timer or a μC ?
  3. Dodgydave
    Jun 22, 2012
    5,150
    769
    use a 555/6 timer circuit like this , alter the resistor values to suit your delays..
  4. djsfantasi
    Apr 11, 2010
    2,905
    878
    After what moves? Is the automatic stop to happen 15-20 seconds after something is powered on or after an event occurs (something moving)?
  5. #12
    Nov 30, 2010
    16,682
    7,322
    Will this do it for you?
    Edit: This needs a latch, but if the OP never comes back, or his circuit is nothing like this, I won't spend the time to make one.
  6. Cgau
    Nov 25, 2013
    5
    yurp..we also use a motor..because our project is about a movements
  7. Cgau
    Nov 25, 2013
    5
    if can it will stop after it move a few seconds..but it also can stop for about a few second before it move again..
  8. Cgau
    Nov 25, 2013
    5
    nevermind..ok..i will try to use it..
  9. Cgau
    Nov 25, 2013
    5
    where should i put my motor in this circuit?
  10. #12
    Nov 30, 2010
    16,682
    7,322
    What motor? Does it, by some miracle of luck, use 5 volts and only a few milliamps? If it does, attach it to the line that says, "high = on". If not, add an amplifier to the line marked, "high = on" so the amplifier can drive the motor.
  11. #12
    Nov 30, 2010
    16,682
    7,322
    Did you just say you want to change the circuit now?
  12. inwo
    Nov 7, 2013
    2,435
    315
