project - code assistance needed
Discussion in 'Programmer's Corner' started by Anesio, Nov 23, 2008.
  1. Anesio
    Oct 21, 2008
    I'm programming in c language using pelles c version 5 but dos.h libraries
    are not supported. can anyone tell me where can i find
  2. Jishnu
    Dec 4, 2008
    The compiler you're using must be Windows-based. Hence, you can't use the dos.h header which is non-standard. If you still want the functionalities of dos.h, you'll have to switch to DOS-based compilers like the ones by Borland. Of course, you'll be able to do similiar things in Pelles' too. Only the function names would vary.
