Project box mounting
Discussion in 'The Projects Forum' started by mooseo, Jan 6, 2011.
  1. mooseo
    Jan 6, 2011
    Hi all,
    I've got a small circuit board and an aluminum project box it needs to fit in... I'm looking for suggestions on how to mount it in place. The box is too thin to tap easily, though I guess I could have a nut on the outside (but that wouldn't look so pretty). In the past, I've used double-stick tape for this sort of thing, but it seems like a kluge.
    I'd appreciate any suggestions.
    Thanks,
    mike
  2. #12
    Nov 30, 2010
    16,705
    7,358
    There are short, threaded, round or hex shaped tubes, that fit 4-40 or 6-32 threads so you can only show the pan head of a bolt on the outside of the box. The hex spacer threads on the end of that tiny bolt, then the circuit board, then another short bolt.
    You might mount a switch or volume control on the circuit board and by mounting that to the box, thus fasten the circuit board in place.
    There. 2 ideas.
  3. hobbyist
    Distinguished Member
    Aug 10, 2008
    774
    65
    Or cut a piece of thin wood to fit snugly in the box and glue it in.
    Then use it as a chasis to attach hardware (standoffs, ect...) too.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Put insulators (scotch tape, masking tape, foam, whatever) and let it float. The wires will keep it still for the most part.
    There are as many ideas for mounting as their are people. If you're board is empty on the edges you can make a pair of slots with wood or plastic and slide it in. Many cases have this feature already molded in.
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Hot melt glue also works well. Just be sure there are not shorts to the box.
    John
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,729
    The nomenclature for the items in #12's reply is "standoffs". Your local Radio Shack store carries at least two types of standoffs; insulated and non-insulated.
    See this link for photos and Radio Shack part numbers: http://www.radioshack.com/family/in...andoffs&filterName=Type&filterValue=Standoffs
    If you use just a bit of nail polish on the standoffs' screw heads, they won't vibrate loose by themselves. A tiny dab'll do it.
  7. mooseo
    Jan 6, 2011
    Thanks a bunch for the suggestions!
    Mike
