project based on renewable energy resources
Discussion in 'The Projects Forum' started by electronicslover, Apr 23, 2010.
  1. electronicslover
    Mar 5, 2010
    28
    hi..
    i need a circuit based on
    Design /technolagy/application of solar energy or other types of renewable energy technologies
    any help would be certainly appreciated...
  2. retched
    Dec 5, 2009
    5,201
    313
    Do you have any ideas or even a form of renewable energy you want to look into?
  3. electronicslover
    Mar 5, 2010
    28
    well..the project should be cost effective and am required to stress upon solar energy...
  4. retched
    Dec 5, 2009
    5,201
    313
    I dont think cost-effective and solar can be used in the same sentence. ;)
  5. electronicslover
    Mar 5, 2010
    28
    well..
    then it should be the one related to tapping solar energy only...
    well cost is not an issue as am not required to submit any hardware...
  6. retched
    Dec 5, 2009
    5,201
    313
    Do you have any idea what you want the power to do?
    Run a car? House? Street light? Calculator? Flashlight?
  7. electronicslover
    Mar 5, 2010
    28
    well..am required to propose an idea of how to use solar energy in our campus effectively...application based
  8. electronicslover
    Mar 5, 2010
    28
    streetlight sound cool to me... ;)
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I suppose you think that someone is going to post a circuit that you can turn in as a homework assignment and get credit for it?
    It doesn't work like that.
    You would learn nothing, except how to talk someone else into doing your work for you.
    You need to do some research into how to harness solar energy in various ways - and then chose an approach that seems feasible.
    Then you design a circuit to implement the concept, and test it.
  10. electronicslover
    Mar 5, 2010
    28
    well..
    i just believed that someone can suggest few links from where i can study various projects for the better understanding of how to proceed with my project...
  11. Markd77
    Sep 7, 2009
    2,803
    594
    It doesen't require much electronics but the most cost effective / benefit to be gained from solar is solar water heating. If I wasn't in a flat that would be the first thing I'd do.
  12. kingdano
    Member
    Apr 14, 2010
    377
    19
    you should start with a google search - come back with an idea and schematic and then people will help you.
    this is not a homework service.
    it is a place to get advice and tips if you are stuck
