Project based on IR thermal imaging
Discussion in 'General Electronics Chat' started by sub1zero, Jan 26, 2010.
  1. sub1zero
    Jan 26, 2010
    Hello fellows. I'm planning to do a project based on infrared thermal imaging. It was suggested by a professor of mine but I have absolutely no idea on what/how/where I'm supposed to begin. :confused: Would really appreciate some/any suggestions and ideas. Cheers!
  2. retched
    Dec 5, 2009
    5,201
    313
    Wow. The first thing I would suspect you need will be an IR-sensitive CCD. The standard CCDs will not see heat(very well). So, if you procure an IR-charge--coupled--device, you would then use a video circuit to display the information.
