Project:AN1015-lead acid battery charger
Discussion in 'The Projects Forum' started by misseny, Mar 22, 2009.
  1. misseny
    Mar 22, 2009
    i am a student from Malaysia, interested for doing Programmable Lead Acid Battery Charger published in AN1015. But there is some problem on how determining the value of label component in this circuit eg Ccomp1,Rcomp etc. I have upload the circuit for reference. I am very grateful if anyone can help me to give guidance and i want to learn from anyone experienced doing this project.I would like to charge 12V lead acid battery. Any information about this topic is really needed.
    thanks
    misseny
    Malaysia
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Please post attachments in Portable Document Format.
    Conversion is free at PDF Online
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Hello thatoneguy,
    The question is based on figure 10 on page 9 of the attached PDF from microchip.
    Greetings,
    Bertus
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Looks to me like they (Microchip) discontinued the PIC16HV785. They still make the PIC16F785.
    From the application note, on page 9, under the named components:
    "HARDWARE FEEDBACK TO PWM: OP1 IS CURRENT SENSE SIGNAL.
    ERROR AMP. Ccomp1/Ccomp2/Rcomp ARE
    LOOP COMPENSATION COMPONENTS."
    In the lower right corner:
    "COMPONENTS THAT DO NOT HAVE A NUMERICAL
    VALUE ASSOCIATED WITH THEM ARE DEPENDENT
    UPON THE VOLTAGE/CURRENT SPECIFICATIONS OF
    THE PARTICULAR APPLICATION.
    CONSULT MICROCHIP FOR GUIDANCE IN DEFINING
    THESE COMPONENT VALUES."
    I see you've requested information on the Microchip message board, under someone else's request that has received no response since October of 2008.
    You might try searching for similar requests by others on that board.
    If you're still not getting anywhere, try writing to Microchip tech support directly, but give more specifics about the battery you wish to charge; eg: voltage, charge current, float voltage, etc.
  5. misseny
    Mar 22, 2009
    hye...
    thanks to bertus for the attached pdf....
    thanks for the response.
    i would like to charge 12V lead acid battery...
    details i will update later....i will find it...
    and for information, i want use this circuit for solar application...
    how u think about it?...
    thanks
    misseny
    Malaysia
  6. misseny
    Mar 22, 2009
    i want to charge 12V lead acid battery...
    i need your suggestion about what value of labeled component that i should use as well.
  7. tuci
    Jan 8, 2010
    Hi all
    Download the PowerTool 200 Software, this calculate the missing component values. The first step is fill the circuit data in the program, after this you will see the component values...
    Istvan
    Hungary
