I have this beautiful old school clock, built in 1952 and still works great.
it's designed to be a slave, driven synchronously from a master clock in the principals office.
It requires a 24 Volt DC pulse once per-minute to operate, I built an AC Line powered driver for it years ago, but needing the line cord sucks.
My goal is to create a battery powered driver for this clock, so it can hang on the wall without wires.
The mechanism has a solenoid coil of about 680 ohms resistance, which would draw about 35 ma @ 24 volts.
The power required is (24 * 0.035) = 0.84 watts, times duty cycle, (0.2 / 60) * 0.84 = .0028 watts (assuming a 200 ms pulse, every minute)
An alkaline "D" cell is supposed to contain about 20 watt-hours of energy, so it might last 1.5 years- (theoretically?)
I am considering the following architecture:
3 VDC power source- 2 "D" cells- I want it to run for at least a year between battery changes.
Micro-controller running 32.768 Khz crystal for time keeping- creating the once per minute pulse.
Simple boost converter to charge a capacitor to around 30 V.
What I am considering is having the boost converter shut down most of the time, then have the converter kick in after every pulse to re-charge the capacitor. This would conserve power, no wasted quiescent current from the boost converter once the capacitor is fully charged.
For simplicity, I was considering having the micro-controller generate the pulses for the boost converter, operating in "fixed-on-time" mode.
A comparator would monitor the capacitor voltage, the micro would stop making pulses once the capacitor is charged.
Anyone have any ideas on how to do this simpler, better, cheaper?
