Project 01
Discussion in 'The Projects Forum' started by questionaire, Sep 4, 2013.
  1. questionaire
    Sep 4, 2013
    how to make car controller using photodiode? and body car using DC motor using relay
  2. wayneh
    Sep 9, 2010
    12,388
    3,244
    Are you asking how to make a line-following robot? Try searching on that term.
    I can't understand your request.
  3. questionaire
    Sep 4, 2013
    sorry for not details.
    so here, i want to make car control using DC motor with relay..so in my remote car controller i want to use photodiode only. so once i touch photodiode, i want it send signal to car control to move forward & reverse.
  4. strantor
    Oct 3, 2010
    4,302
    1,989
    This language barrier may be too high to scale.
  5. wayneh
    Sep 9, 2010
    12,388
    3,244
    So you have a remotely controlled car. A toy?
    Instead of using a joystick, you want to use your finger to block ambient light to a photodiode?
    If this is close, I think you will need one photodiode for each direction. The photodiode has no directionality - it is either lit or not lit.
  6. Phaedo
    Sep 4, 2013
    13
    Try drawing a picture of what you want and show us that. Which language do you speak natively?
