[15kw] to power e-plane. Is such a device available?
Sure, how long?[15kw] to power e-plane. Is such a device available?
I remember a man, seeking technical advice, being condescendingly told it was impossible, yet later someone DID IT.Some miliseconds at most? 15kW over 1 second is 15kJ. A capacitor that large I´d guesstimate to be roughly 500 grams, maybe more.
So, a small model plane? Yes, but it will never take off. Something like the Solar impulse? Yeah sure, but there is a reason why they use batteries instead of supercaps... - supercaps are great at delivering extreme peak power, but they suck at energy stored per unit weight compared to batteries, and their charging and discharging circuits are more complicated as well.
They charge rapidly because they don't have much capacity.I remember a man, seeking technical advice, being condescendingly told it was impossible, yet later someone DID IT.
I, the "antimarx" want at least 45 min. of flight time, & am interested in ultracaps because they charge VERY rapidly, and may be less expensive than Li-ion batteries. One thoughtful person mentioned LIC's.
Thanks John, others gave me enough of the basics, showing that ultracaps are not feasible.Lots of possibilities. In the context here, I suspect the TS meant Lithium Ion Capacitor. A type of supercap with higher voltage.
The TS is concerned that anyone who points out the current limits of capacitors to provide such a power (45 minutes at 15 kW) for an electric powered airplane, is condescending. I would like see his/hers/its design so we can help improve it, rather than putting that task on us. This is a forum to help people, not do it for them.
Go ahead, use LIC. We can find crowd funding for you at the point you have something reasonable designed.
John
A "LIC" is a Lithium Ion capacitor - [maybe the wrong abbreviation]. Someone mentioned it @ this site [though not necessarily this group or thread].They charge rapidly because they don't have much capacity.
Way more expensive per watt than Lipos.
I'll byte, what's a LIC?
What is the "TS"? I have an EXCELLENT airframe design, & the very high price of a motor & Li-ion batteries prompted me to find alternatives. By the way, I was there, & it was one of many valuable lessons in humility I've experienced. Also, I try not to take things personal - & I chose battles very carefully. signed, the AntimarxLots of possibilities. In the context here, I suspect the TS meant Lithium Ion Capacitor. A type of supercap with higher voltage.
John
Ahh, I see. The problem is they have about 1/20 the power for the same weight as LIPOs.A "LIC" is a Lithium Ion capacitor - [maybe the wrong abbreviation]. Someone mentioned it @ this site [though not necessarily this group or thread].
I appreciate his help, and my search gave good technical info on them.
Yes. Lots of people can do that for you.Is such a device available?
by Duane Benson
by Aaron Carman
by Jake Hertz
by Jake Hertz
