programming VS-2 servo motor
Discussion in 'Embedded Systems and Microcontrollers' started by jayk, Dec 29, 2011.
  1. jayk
    Dec 18, 2011
    I have done the following program but servo motor is rotating fully. I cant control the angle.
    Code ( (Unknown Language)):
    1.
    2. #include<avr/io.h>
    3. #include<compat/deprecated.h>
    4. #include<util/delay.h>
    5.
    6. main()
    7. {
    8.    sbi(DDRD,5);
    9.
    10.   while(1)
    11.   {
    12.      int i;
    13.
    14.      for(i=10000; i > 0; i--)
    15.      {
    16.          sbi(PORTD,5);
    17.          _delay_ms(0.6);
    18.          cbi(PORTD,5);
    19.          _delay_ms(19.4);
    20.     }
    21.
    22.      for(i=10000; i > 0; i--)
    23.      {
    24.          sbi(PORTD,5);
    25.          _delay_ms(1.5);
    26.          cbi(PORTD,5);
    27.          _delay_ms(18.5);
    28.      }
    29.
    30.
    31.      for(i=10000; i > 0; i--)
    32.      {
    33.          sbi(PORTD,5);
    34.          _delay_ms(2.4);
    35.          cbi(PORTD,5);
    36.          _delay_ms(17.6);
    37.      }
    38.
    39.
    40.    }
    41. }
    42.
    43.
  2. Markd77
    Sep 7, 2009
    2,803
    594
    Are you waiting long enough for it to move? 10000 X 20ms = 200 seconds
  3. jayk
    Dec 18, 2011
    then how long should i wait.can you give me suggestion
  4. Markd77
    Sep 7, 2009
    2,803
    594
    According to the code it should change position every 200 seconds which is 3 minutes and 20 seconds.
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    You are only setting and clearing port D.5, so it will only go in one direction, if it moves at all.
    Need a schematic of how everything is hooked together to really give advice. Usually at least 3 pins are used, one for enable, and one for fwd/reverse or phase if using a stepper.
