Programming the HCS12 with BCD and Keypad.
Discussion in 'Programmer's Corner' started by hydra504, Nov 22, 2008.
  1. hydra504
    Oct 18, 2007
    16
    I am programming a AXIOM CML12S512 board and I succesfully got my counter to count up and count down using a BCD LED display counter hooked up to the ports on the board. Now the issue that I am having is a polling issue with the keypad.
    What I want is to exit upon hitting the keypad button "once" and go to the next procedure or exit the program over all.
    The problem I am having is that since I created a one second delay for the BCD LED display, every time I hit a button on the keypad I have to push that button several times inorder for it to respond, or I hold it for about 1 second and it reponds then.
    Here is my sample code for the counter that I created. Any help would be greatly appreciated.
    while( (numPress != '2') && (numPress != '3') ){
    //Increment the array and store it
    newNumVal = number_array2[index];
    index = ((index + 1)%10);
    //Delay for the count up
    for (timeDelay1 = 0; timeDelay1 < 24; timeDelay1++){
    for (timeDelay2 = 0; timeDelay2 < 30000; timeDelay2++){
    PTP = newNumVal;
    }//End of delay.
    //Exit the loop using the C on the keypad
    numPress = kbhit(0);
    }//End of While loop. Jumps out only if kkbhit() has detected a hit on the key pad.
    //Check if the count stop or count up button is pressed
    if(numPress == '3'){
    LCDInit(0); //LCD clear
    LCDputs("Start count down\0"); //Display string
    count_down(newNumVal); //Call the count_down procedure
    //return to main
    if(numPress == '2'){
    terminate();
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Can you write an interrupt routine? That will get rid of the polling delay.
  3. hydra504
    Oct 18, 2007
    16
    I have no clue how to do that.... :(
