Programming Sounds
Discussion in 'Embedded Systems and Microcontrollers' started by Chris15, Dec 17, 2010.
  1. Chris15
    Thread Starter Active Member
    Apr 15, 2009
    252
    Hellloooo
    I have an ATtiny13A that i have programmed to play a small nokia tune when activated
    My Question is to find out how the Hex fille was made to sound like a nokia tune, and am trying to make the tune different or just want to know how it is done, i knw the ATtiny13A Does not have alot of memory like 1k but i want to know how u can make a song or sound into a hex file ready for programming
    Chris
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    Does your current project function ok?
    Have you contacted the author of the .hex file to see if you can get the source code?
    There are a few ways to do it, I'm used to PICs, but the concept is the same. Google should show some results for C routines for sound generation on microcontrollers.
  3. Chris15
    Apr 15, 2009
    252
    yes My current Project works Great! i am very pleased at how it works, i just thought i could keep the same circuit, but put a short christmas carole or something anything, i just wanted to learn how that part worked
  4. jpanhalt
    Jan 18, 2008
    5,699
    909
    Agree on getting the source code from the author. If that fails, you can also search on a disassembler to convert hex into assembly. You do not get comments that way, but you might be able to tell enough from it to write your own code. John
  5. Chris15
    Apr 15, 2009
    252
    What is a Source code?
    So if i was him, and i wanted to make my tune, what would he have done, do i get an mp3 file, and put it in a program that makes it into a hex?
    My understanding of Programming is as simple as, get a hex file, connect the Chip, press program, so i dont understand all the stuff people write in AVR Studio 4 board, the #include io.h, Void, and the random { and }, PORTB, DDRB those things i have seen people write but i dont know what that is what it means
    Can a Hex file for one chip, for example my Nokia Tune for a ATtiny13A be used on ANY Atmel chip?, are all hex files the same
    Chris
  6. nerdegutta
    Dec 15, 2009
    2,565
    805
    When all #include io.h void, and the random { and } plus a bunch of more stuff is put in a system, that is called "source code", from the source code, a compiler and linker makes it into a hex-file.
    PS. I've read about some people who program direct in hex. God bless them!
  7. Kermit2
    Feb 5, 2010
    3,845
    963
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
  9. Chris15
    Apr 15, 2009
    252
    Aight thanks Boys, im gna explore that more, another quastion bout AVRISP MKII
    Mine has a 6 pin female socket, can i use that 6 pin socket for BIG AVR Chips, like the ATmega328P and other 14, 20, 40 pin IC's or do i need a different programmer?
  10. Kermit2
    Feb 5, 2010
    3,845
    963
    Google "ATmega programming pins"
  11. maxpower097
    Feb 20, 2009
    795
    388
  12. hgmjr
    Jan 28, 2005
    9,030
    214
    I have attached an image of a partial list of AVRs that can be programmed with the AVRISP MKII.
    The AVRs on this list vary from the simpliest 8-pin up to the complex 64-pin versions. All AVR's share the same common CPU core so the code you write for one AVR can very easily be migrated to a more feature rich AVR device.
    I recommended the AVRISP MKII to provide you with the maximum flexibility in programming as many AVR 8-bit microcontrollers as possible. I don't think you will soon outgrow this programmer.
    hgmjr
