Programming Question. Help!!!
Discussion in 'Embedded Systems and Microcontrollers' started by Ricky Sum, Jun 30, 2016.
  1. Ricky Sum
    May 6, 2016
    13
    Hi, I have a programming question and I have answered it but not sure was it correct. Please advise. Thank
    void ShowCost( float fltCost )
    Identify the errors in the following statements, if any, in calling the function showCost().
    A. showcost(fltTotal);
    Answer: Case sensitive, this will fail
    B. ShowCost( float fltTotal);
    Answer: When calling the function, you pass the (float) parameter, don't declare it as 'float'
    C. ShowCost();
    Answer: A (float) parameter must be passed to the function.
    D. fltPrice = ShowCost(fltTotal);
    Answer: The function does not return a value, so "fltPrice = " is wrong.
    Answer: A correct call to the function:- ShowCost(fltTotal);
  2. AlbertHall
    Jun 4, 2014
    2,263
    448
    Hi again!
    I think you should have more confidence in your own answers :)
    absf and JWHassler like this.
