Hello and thanks for your help
Several years ago I programmed a 18F2550 using a customized programmer that is sold in the local market. You had to take the chip out of its socket and put it in the programmer, upload the HEX file and then put the chip again in the socket.
Now, with the view of doing onchip programming I am planning to use PICKIT3. But I have never used it so I have several questions. (Btw, I am planning on using now the 18F4450 or maybe 18F4553)
1) I used MPLAB IDE to write my programs. Can I still use it or should I use the -I heard- new MPLAB X??
2) How do I connect the PICKIT3 to the microcontroller??
3) As a compiler I vaguely remember I used the C18 Lite. Do I have to use a different one?
Thank you for the help.
