Hi there
I´m newbe in electronics also in this forum I hope this is the rigth place to put this post... I have some devices that uses pic 16f876A . Every one should have the same program but diferent device id. I read the hex code in every one, I compare all those hex file using a program (Hexcmp) and all the hex files are identical, may some one explain me why? Should the code be different at least a bit because somewhere there is a different device id?
Thanks in advance
Thanks in advance
