Programming P89v51RD2
Discussion in 'Embedded Systems and Microcontrollers' started by mikevictor92, Apr 26, 2015.
How to check P89V51RD2 IC
  1. Yes
    0 vote(s)
    0.0%
  2. No
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. mikevictor92
    Apr 26, 2015
    Hello Friends,
    I had tried programming p89v51rd2 IC with flashmagic . I burnt the same code in 5 same IC's but only 1 IC gave the output and the other 4 IC's aren't giving any o/p.
    How can I check whether the IC's are working or not?Is there any way to troubleshoot the IC's coz the IC's are too costly..Pls Help...
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    A programmer will normally run several checks on a device before erasing and programming. If the programmer is happy with it, then in my experience that is usually good enough. There are more than enough reasons for things not to work besides bad parts, which in a career spanning half a century has happened maybe twice.
  3. shteii01
    Feb 19, 2010
    3,500
    511
    p89v51rd2 is a chip.
    flashmagic is software.
    What did you put between chip and software?
  4. mikevictor92
    Apr 26, 2015
    I had Programmed all the chips using a 89v51 Burner kit..Out of them 1 IC worked fine while the other 4 IC's didn't gave any o/p...
