Hello, We r interfacing 8880 to LPC2148. But not getting dialing tone. The code as shown below. Pls guide us.
// Dialling phone number
#include <Philips\LPC2148.h>
#include <stdio.h>
#include <ctype.h>
#include <stdlib.h>
#include <string.h>
char buffer[33];
int s;
#define Relay 1
#define CS_Dial 30
#define RW_Dial 25
#define RS_Dial 29
#define D0 4
#define D1 5
#define D2 6
#define D3 21
void delay(int counter)
while(--counter);
void Set_Control(void)
IO1SET |= (1<<D3);
IO0CLR |= (1<<D2);
IO0SET |= (1<<D1);
IO0SET |= (1<<D0);
IO0SET |= (1<<RS_Dial);
IO0CLR |= (1<<RW_Dial);
IO0CLR |= (1<<CS_Dial);
IO0SET |= (1<<CS_Dial);
delay(1200);
IO1CLR |= (1<<D3);
IO0CLR |= (1<<D2);
IO0CLR |= (1<<D1);
IO0CLR |= (1<<D0);
delay(1200);
void init_dial(void)
IO0SET |= (1<<RW_Dial);
IO0SET |= (1<<D0);
IO0SET |= (1<<D1);
IO0SET |= (1<<D2);
IO1SET |= (1<<D3);
IO0CLR |= (1<<Relay);
IO0DIR |= (1<<CS_Dial);
IO0DIR |= (1<<RW_Dial);
IO0DIR |= (1<<RS_Dial);
IO0DIR |= (1<<Relay);
IO0DIR |= (1<<D0);
IO0DIR |= (1<<D1);
IO0DIR |= (1<<D2);
IO1DIR |= (1<<D3);
delay(2000);
IO0SET |= (1<<D0);
IO0SET |= (1<<D1);
IO0SET |= (1<<D2);
IO1SET |= (1<<D3);
delay(2000);
//dials a number
void Dial_Digit(void)
switch ( s )
case 0x00:
IO1SET |= (1<<D3);
IO0CLR |= (1<<D2);
IO0SET |= (1<<D1);
IO0CLR |= (1<<D0);
break;
case 0x01:
IO1CLR |= (1<<D3);
IO0CLR |= (1<<D2);
IO0CLR |= (1<<D1);
IO0SET |= (1<<D0);
break;
case 0x02:
IO1CLR |= (1<<D3);
IO0CLR |= (1<<D2);
IO0SET |= (1<<D1);
IO0CLR |= (1<<D0);
break;
case 0x03:
IO1CLR |= (1<<D3);
IO0CLR |= (1<<D2);
IO0SET |= (1<<D1);
IO0SET |= (1<<D0);
break;
case 0x04:
IO1CLR |= (1<<D3);
IO0SET |= (1<<D2);
IO0CLR |= (1<<D1);
IO0CLR |= (1<<D0);
break;
case 0x05:
IO1CLR |= (1<<D3);
IO0SET |= (1<<D2);
IO0CLR |= (1<<D1);
IO0SET |= (1<<D0);
break;
case 0x06:
IO1CLR |= (1<<D3);
IO0SET |= (1<<D2);
IO0SET |= (1<<D1);
IO0CLR |= (1<<D0);
break;
case 0x07:
IO1CLR |= (1<<D3);
IO0SET |= (1<<D2);
IO0SET |= (1<<D1);
IO0SET |= (1<<D0);
break;
case 0x08:
IO1SET |= (1<<D3);
IO0CLR |= (1<<D2);
IO0CLR |= (1<<D1);
IO0CLR |= (1<<D0);
break;
case 0x09:
IO1SET |= (1<<D3);
IO0CLR |= (1<<D2);
IO0CLR |= (1<<D1);
IO0SET |= (1<<D0);
break;
case 0x0b:
IO0SET |= (1<<D0);
IO0SET |= (1<<D1);
IO0CLR |= (1<<D2);
IO1SET |= (1<<D3);
break;
case 0x0c:
IO0CLR |= (1<<D0);
IO0CLR |= (1<<D1);
IO0SET |= (1<<D2);
IO1SET |= (1<<D3);
break;
IO0CLR |= (1<<RS_Dial);
delay(2000);
void Dial( void )
unsigned char ii = 0;
delay(40000);
IO0SET |= (1<<Relay);
delay(50000);
sprintf(buffer,"%s","9427892501* ");
while ( buffer[ii] != '*')
s = buffer[ii] - '0';
Dial_Digit();
RC1 = 0;
while(RC1 == 0)
IO0DIR &= (~(1<<D0));
IO0DIR &= (~(1<<D1));
IO0DIR &= (~(1<<D2));
IO1DIR &= (~(1<<D3));
delay(20000);
Get_Status();
RC1 = (RC1>>1);
RC1 &= 0x01;
ii++;
IO0DIR |= (1<<D0);
IO0DIR |= (1<<D1);
IO0DIR |= (1<<D2);
IO1DIR |= (1<<D3);
delay(2000);
for(ii=0;ii<100;ii++)
delay (50000);
} //delay for giving ring to Tel.no.
//####################### Main Fuction ###############################################
int main (void)
int i;
init_dial();
Set_Control();
delay(2000000);
Dial();
while(1);
return 0;
#include <stdio.h>
#include <ctype.h>
#include <stdlib.h>
#include <string.h>
char buffer[33];
int s;
#define Relay 1
#define CS_Dial 30
#define RW_Dial 25
#define RS_Dial 29
#define D0 4
#define D1 5
#define D2 6
#define D3 21
while(--counter);
IO1SET |= (1<<D3);
IO0CLR |= (1<<D2);
IO0SET |= (1<<D1);
IO0SET |= (1<<D0);
delay(1200);
IO1CLR |= (1<<D3);
IO0CLR |= (1<<D2);
IO0CLR |= (1<<D1);
IO0CLR |= (1<<D0);
delay(1200);
IO0SET |= (1<<D0);
IO0SET |= (1<<D1);
IO0SET |= (1<<D2);
IO1SET |= (1<<D3);
IO0DIR |= (1<<D0);
IO0DIR |= (1<<D1);
IO0DIR |= (1<<D2);
IO1DIR |= (1<<D3);
delay(2000);
IO0SET |= (1<<D0);
IO0SET |= (1<<D1);
IO0SET |= (1<<D2);
IO1SET |= (1<<D3);
delay(2000);
//dials a number
switch ( s )
case 0x00:
IO1SET |= (1<<D3);
IO0CLR |= (1<<D2);
IO0SET |= (1<<D1);
IO0CLR |= (1<<D0);
break;
case 0x01:
IO1CLR |= (1<<D3);
IO0CLR |= (1<<D2);
IO0CLR |= (1<<D1);
IO0SET |= (1<<D0);
break;
case 0x02:
IO1CLR |= (1<<D3);
IO0CLR |= (1<<D2);
IO0SET |= (1<<D1);
IO0CLR |= (1<<D0);
break;
case 0x03:
IO1CLR |= (1<<D3);
IO0CLR |= (1<<D2);
IO0SET |= (1<<D1);
IO0SET |= (1<<D0);
break;
case 0x04:
IO1CLR |= (1<<D3);
IO0SET |= (1<<D2);
IO0CLR |= (1<<D1);
IO0CLR |= (1<<D0);
break;
case 0x05:
IO1CLR |= (1<<D3);
IO0SET |= (1<<D2);
IO0CLR |= (1<<D1);
IO0SET |= (1<<D0);
break;
case 0x06:
IO1CLR |= (1<<D3);
IO0SET |= (1<<D2);
IO0SET |= (1<<D1);
IO0CLR |= (1<<D0);
break;
case 0x07:
IO1CLR |= (1<<D3);
IO0SET |= (1<<D2);
IO0SET |= (1<<D1);
IO0SET |= (1<<D0);
break;
case 0x08:
IO1SET |= (1<<D3);
IO0CLR |= (1<<D2);
IO0CLR |= (1<<D1);
IO0CLR |= (1<<D0);
break;
case 0x09:
IO1SET |= (1<<D3);
IO0CLR |= (1<<D2);
IO0CLR |= (1<<D1);
IO0SET |= (1<<D0);
break;
case 0x0b:
IO0SET |= (1<<D0);
IO0SET |= (1<<D1);
IO0CLR |= (1<<D2);
IO1SET |= (1<<D3);
break;
case 0x0c:
IO0CLR |= (1<<D0);
IO0CLR |= (1<<D1);
IO0SET |= (1<<D2);
IO1SET |= (1<<D3);
break;
delay(2000);
void Dial( void )
delay(40000);
delay(50000);
Dial_Digit();
RC1 = 0;
while(RC1 == 0)
delay(20000);
Get_Status();
RC1 = (RC1>>1);
RC1 &= 0x01;
ii++;
IO0DIR |= (1<<D0);
IO0DIR |= (1<<D1);
IO0DIR |= (1<<D2);
IO1DIR |= (1<<D3);
delay(2000);
delay (50000);
int main (void)
int i;
init_dial();
Set_Control();
delay(2000000);
Dial();
while(1);
return 0;
