Hi everybody,
Im trying to use the signal from the TV remote control to trigger the 12F615 in order to produce PWM for output, via photo diode as receiving the signal.
Having though of using op amps to receive and amplify the signal to 5V, then feed to the MCU, to produce the O/P, this involves quite number of components, perhaps I could use the built-in comparator of the 12F615.
I used to play with FLOW CODE to program my PIC projects, however it seems a difficult task for this software to program the built-in comparator mode. Hoping the experts here could guide me in C programming, to have my MCU working.
The circuits of my project and datasheet of the MCU attached.
oookey
oookey
