Hi
I am new to micro controllers I am using ATMega 32, I want to achieve the following Conditions,how to write the programme in WinAVR Programmers Notepad Using C/C++ .
PinB0 as Input
PinB1 as output
PinB2 as Input
1) if B0 is 1 and PinB2 is 1 then PinB1 should be 0
2) If B0 is 0 and PinB2 is 1 then Pin B1 should be 0
3) if B0 is 0 and PinB2 is 0 then Pin B1 should be 0
4) if B0 is 1 and pinB2 is 0 then Pin B1 should be 1
Noe: 1.Input at Pin B0 will appear for a short time when Push Button is pressed momentarily
2. Input at Pin B2 will be continuous or short time depending upon the source for this signal.
PinB0 as Input
PinB1 as output
PinB2 as Input
