Can the arduino development board be used to program other non-arduino avr microcontrollers too?I'm buying the Arduino UNO R3 tomorrow.Also there's the leonardo which is newer but it seems to use the surface mounted Atmega32u4.So how do you implement this in the final pcb design.Like, I understand how it works with the usual DIP mcus,you plug it in,program it and then use it in the final circuit.But I don't understand how the surface mounted mcu is programmed and implemented in the circuit(physical implementation). I couldn't find the info I wanted online.Could please someone explain this or provide some relevant links?
Thanks.
Thanks.
