programming a weller soldering station
Discussion in 'General Electronics Chat' started by Swifty01, Oct 8, 2012.
  1. Swifty01
    Aug 30, 2011
    Can anyone let me know if a Weller WSD151 soldering iron station can be re programmed without the programming unit? If so how?
    Swifty01
  2. t06afre
    May 11, 2009
    5,939
    1,222
    I am not sure what you want to do here. Do you want to just use the "solder pencil" without the control unit?
  3. Swifty01
    Aug 30, 2011
    No I have one of these and I would like to change the temperature as it's to low for the job I'm doing. I do not have the external unit for doing this so can it be done without it. I have had a look inside the base unit and there are two pins by the up/down push switch can this be used for reprogramming the temperature?
